Activity Forums Apple Final Cut Pro Legacy Exporting Multiple clips on a sequence
  • Exporting Multiple clips on a sequence
    Posted by Pedro Monsalve on July 26, 2010 at 2:09 pm
    Hi ya’ll, firstable thanks in advance, the COW is the best.
    Quick question I have 5 small edits on the same sequence, I just have separated them by 10 seconds and marked them to differentiate them, is there a way to just export the sequence and somehow it ill get split into 5 different clips? Or should I have to keep doing what I’m doing: marking in/out on each edit, export, then move on to the next one … etc… or separate sequences …
    I just though perhaps markers and bit of scripting could solve this issue.
    Thanks in advance.
    Pedro Monsalve replied 16 years, 1 month ago 4 Members · 4 Replies
  • Michael Sacci
    July 26, 2010 at 2:31 pm
    You can media manage the sequence and it will export a separate clip for each clip on the timeline.
  • Mark Jenner
    July 26, 2010 at 3:11 pm
    pop each edit in to its own sequence with in and out points
    then open a new bin and put all those sequences in to that bin
    then select that bin and go to file batch export make sure the folder in selected and the sequences inside it
    choose your settings and hit export
    hope that helps
    mark jenner endorfintv
  • Brian Miller
    July 26, 2010 at 6:26 pm
    you could also subclip each in/out point on your main sequence, then batch export the subclips
  • Pedro Monsalve
    July 26, 2010 at 7:43 pm
    Yeap currently all of these depending on what I have … I don’t understand the Media Manager thing … but is OK, I just thought perhaps there was some other way … seems like a workaround, but is OK.
    Thanks, all.
