Activity Forums Adobe After Effects exporting multilayered photoshop sequences
  • exporting multilayered photoshop sequences
    Posted by Andrew Hill on November 30, 2005 at 9:04 pm
    OK,
    Is there anyway to export a Quicktime movie from After Effects as a photoshop image sequence, but where each image is a multilayered psd?
    Trying to preserve a keyed out area in the image so when i open the docs in photoshop those areas are already transparent. Having problems doing this unless I do the whole “save frame as” photoshop layers. Problem is i need to do this for every frame. And that would take forever. And when you render out an image sequence, it seems like it just flattens the layers.
    WAAAAA!!!!
    Help.
    Drew
    Andrew Hill replied 20 years, 9 months ago 3 Members · 6 Replies
  • John Dickinson
    November 30, 2005 at 10:08 pm
    How about using the FLM format. You can save out your comp as a filmstrip (with Alpha) and open that up directly in Photoshop.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • John Dickinson
    November 30, 2005 at 10:10 pm
    This would also flatten the comp however 🙁
    JD
    John Dickinson
    Motionworks
  • Andrew Hill
    November 30, 2005 at 10:27 pm
    I wonder if I’m doing something incorrectly in photoshop. All I want to do is have photoshop recognize the area I keyed (in After Effects) around the subject as transparent.
    I feel like this should be really easy. Maybe the multilayered psds from an image sequence isn’t the way to go.
    Just want photoshop to recognize the transparency.
    Drew
    Thanks for the reply though.
  • John Dickinson
    November 30, 2005 at 10:40 pm
    When you save a frame as Photoshop layers, keyed areas SHOULD be recognised as transparent in Photoshop (the keyed areas become part of that layer’s alpha channel). If you email me the file I can take a look if you like (john@motionworks.com.au)
    JD
    John Dickinson
    Motionworks
  • Canwal Brar
    December 1, 2005 at 11:06 am
    hello andrew
    while exporting multilayered photoshop sequences
    try
    filmstrip format(.flm)
    or
    photoshop sequence(.psd)
    send your question in detail let us find a better a way out if the above does’nt cater to tour problem
    canwal brar
  • Andrew Hill
    December 1, 2005 at 8:17 pm
    It’s a PNG sequence. This supports the transparency from the key. Found out from Seth in the Photoshop forum.
    Man. I wonder why the Photoshop sequence wouldn’t work.
    Anyway.
    Thanks again.
    Drew
