Activity Forums DaVinci Resolve Exporting mpeg2 in .mxf wrapper
  • Exporting mpeg2 in .mxf wrapper
    Posted by Nicolas Alonso on April 28, 2023 at 3:57 pm
    Hi there,
    I’m having a situation that don’t seem to be able to solve.
    Need toExport mpg2 1440×1080 in an .mxf wrapper, interlaced.
    My master is a prores 1920×1080 and have not been able to find the correct setting.
    Either I cant change the dimension, or the codec is different, but cant seem to find the complete combination.
    Can anybody throw me a life saver?
    Shahid shahan replied 3 years, 3 months ago 2 Members · 1 Reply
  • Shahid shahan
    April 30, 2023 at 3:20 am
    Hey nicolas,
    Note:that the ProRes 1920×1080 master will be automatically scaled down to 1440×1080 to match the export resolution.
    Follow these
    • In the Deliver page, select the “Custom” preset.
    • Set the “Format” to “MXF OP1a”.
    • Set the “Video Codec” to “MPEG2”.
    • Set the “Resolution” to “1440×1080”.
    • Set the “Field Order” to “Upper Field First” or “Lower Field First”, depending on your source footage.
    • Adjust other settings as needed (e.g. bit rate, frame rate, etc.).
    • Export the video using the desired file name and location.
    Shahan
