Activity Forums Adobe After Effects exporting mp4 using AE CS3 to DG Fastchannel specs???
  • exporting mp4 using AE CS3 to DG Fastchannel specs???
    Posted by Chris Cleary on May 21, 2009 at 12:28 am
    Ive got a project that I created entirely in After Effects CS3 that needs to be exported to the following specs…
    Standard Definition Commercial Broadcast Specifications:
    • Aspect Ratio 4×3
    • Chroma – Preferred 4:2:2 (MP@ML) (720×512)
    • Chroma – Min 4:2:0 (MP@ML) (720×480) ***
    • GOP All Allowed, IBBP preferred
    • Frames per second 29.97 (NTSC)
    • 2 stereo channel min (audio/video combined)
    • Luminance Level Max 100 IRE
    • Chroma Level Max 120 IRE
    • Setup level 7.5 IRE
    • Timecode Not Used
    Ive read a lot of people talking crap about exporting things from AE and how it gets horrible quality so my question is, how do I export to these specs from AE while maintaining the quality Id want for a TV commercial?
    Thanks in advance for any advice.
    C
    Joey Burnham replied 17 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Chris Cleary
    May 21, 2009 at 3:58 pm
    What are the best quality setting for export in AE? Also, what program would you suggest for the proper compression?
    Thanks for your help, much appreciated.
    Chris
  • Deleted User
    May 21, 2009 at 4:45 pm
    Sorenson Squeeze will do MP4 conversions from a Quicktime animation codec render out of AE. My experience is that the conversions are of a very high quality and should be more than adequate for submission to Fastchannel.
    Lee
    CTV Calgary
  • Joey Burnham
    May 21, 2009 at 6:39 pm
    I use compressor all the time for broadcast stuff. Just use the mpeg-2 program stream preset.
    Joey
  • David Notowitz
    August 20, 2009 at 7:54 pm
    Joey,
    Does the version of Compressor that came with FCP 5.1.4 (Compressor v2.3) have the right high quality Mpeg-2 program stream preset to do this? If so, what is the name of that preset?
    David
  • Joey Burnham
    August 20, 2009 at 8:34 pm
    It should.
    Formats > MPEG-2 > Program Stream
    Joey
  • David Notowitz
    August 21, 2009 at 4:58 am
    I didn’t find a way to do it in Compressor — it may be there, but I just didn’t see it.
    So I tried to compress the DV NTSC footage down to Mpeg-2 using Cleaner 6. The footage comes out fine, except for one strange thing…
    In the compressed finished video, the frame shifts up and down on the screen. I would say it’s maybe only one or two pixels, but it’s a rhythmic even, shifting.
    Any thoughts?
    Notowitz Productions
    We capture the memories that make life worth living.
    https://www.Notowitz.com
  • David Notowitz
    August 21, 2009 at 4:24 pm
    Joey,
    Here’s a SHORT video sample to what I’m describing:
    https://www.notowitz.com/Mpeg2TestHELP.mpg
    David
  • Joey Burnham
    August 21, 2009 at 4:31 pm
    Are you using the preset? Email me and I can just send it to you. I don’t know why you are getting that flickering.
    joeydotburnhamatmedotcom
