Activity › Forums › Avid Media Composer › Exporting MOV settings
  • Exporting MOV settings
    Posted by Paul Cripps on December 2, 2008 at 2:31 pm
    We’ve noticed that the JPEG-B option on the MOV export settings is no longer on our list of choices. Is it a quick fix to get this back or is it a re-install.
    Thanks.
    Ra-ey Saleh replied 17 years, 9 months ago 2 Members · 3 Replies
  • Ra-ey Saleh
    December 4, 2008 at 11:18 pm
    I think it’s probably what Quicktime see to be an old format which you now have to enable.
    Open Quicktime.
    Go to EDIT > PREFERENCES > QUICKTIME PREFERENCES.
    ADVANCED tab.
    And check the ‘Enable encoding using legacy codes’ box.
    Restart Avid.
    Think this will sort it out.
  • Paul Cripps
    December 9, 2008 at 3:37 pm
    That’s done the trick. Many thanks.
  • Ra-ey Saleh
    December 9, 2008 at 8:59 pm
    Incidentally, thus was in the v3.1 Read Me…
    ‘QuickTime 7.4.5 and 7.5 causes washed out video if you use Motion JPEG-B, Avid
    recommends that you use the Avid codecs when using these versions of QuickTime.’
