Activity › Forums › Adobe After Effects Expressions › Exporting Motion Path keyframe data
  • Exporting Motion Path keyframe data
    Posted by Ken De cooman on November 9, 2008 at 8:54 pm
    I’m working on a project between dance, video and architecture. I’m using Trapcode particular to draw a path/curve that’s following someone in the video. To do this I use a light as an emitter and keyframe it’s position throughout the video.
    The result is a curve that AE/Particular draws according to my “Light” position keyframes.
    Here’s the question: how do I export the (x,y,z) data of position of the light each fifth frame, so that I have all those positions in an array as follow example:
    (630,7 , 287,3 , -355,6)
    (634,5 , 256,7 , -356,9)
    (637,8 , 245,4 , -358,7)
    And so on.
    Can I do this using expressions?
    (I could do it manually, but it would be such a lot of work… Really.)
    If I have them in an array I can use them in Rhino to go 3D.
    I’m using adobe CS 3 on macbook pro.
    Thanks so much for every lead that I can get…
    Ken
    Dan Ebberts
    replied 17 years, 10 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    November 9, 2008 at 11:43 pm
    You could do it with a script. Another possibility would be to add this expression:
    value
    And then convert the expression to keyframes (Animation > Keyframe Assistant > Convert Expression to Keyframes). Then just select the property, Edit > Copy, and paste into a spreadsheet or text editor. Then you just need to figure out how to thin the data.
    Dan
