Activity Forums Adobe After Effects Exporting motion graphics with H264
  • Exporting motion graphics with H264
    Posted by Manuel F. rugeles on August 1, 2009 at 2:44 pm
    Hello, I have a problem when exporting my motion graphics (HD 720p) with the H264 codec for uploading it on the web. However, after exporting the h264 quicktime I noticed the picture looks washed out and glows and gradients looks very bad quality. I find it confusing becasuse I´ve exported other motion graphics with this codec before an the results were very good. Any advice? Thanks.
    Manuel F. Rugeles
    Editing and Motion Graphics
    https://www.youtube.com/user/manuelfeliperugeles
    Scott Novasic replied 17 years, 1 month ago 3 Members · 3 Replies
  • Todd Kopriva
    August 1, 2009 at 4:12 pm
    Here’s an After Effects Community Help search for ‘h264 quicktime gamma’ that pulls up several useful resources for this issue.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Manuel F. rugeles
    August 2, 2009 at 9:49 pm
    Thanks for the info. But The solutions provided did not help much. Encoding with the x264 codec does not seems to work and changing or adjusting the transparency mode on the quicktime player movie properties works fine but only to view it on quicktime. Once you upload the video to a video share site it will look again washed out. Also if you view it on the VLC player.
    After trying a lot I found that exporting the movie as h264 directly from AE, using the H264 format preset, gives much better results and no washed out picture. The trick is selecting the format preset H264 and not using the quicktime format options to change the codec to h264 from there (and AE will warn you). I dont know what really happens but I think AE will encode the movie using another encoder than quicktime and this will result in a better h264 movie, since the gamma shift problem is a bug of quicktime. Exporting from quicktime pro or compressor always gives washed out picture, at least in my case.
    I Hope this helps and thanks again.
    Manuel F. Rugeles
  • Scott Novasic
    August 3, 2009 at 6:25 am
    i dont know if it matters much. But I render my ‘master’ animations out in uncompressed animation codec. THEN i use Quicktime pro to export as H264. It allows me to adjust sharpness, hue, saturation etc. It does help me get the ‘look’ I like easier than exporting from AE. I admit to being frustrated with AE h264 output. Im sure its my user error, but its always a hassle. Maybe I am missing something, but I am very comfortable with QT Pro’s export.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
