Activity › Forums › Apple Final Cut Pro Legacy › Exporting more than 2 audio tracks?
  • Exporting more than 2 audio tracks?
    Posted by Tom Douce on April 15, 2010 at 11:58 am
    Hi all,
    I am trying to export a sequence with 6 audio tracks using Menu->File->Export->Using Quicktime conversion… and it seems to be impossible to export to more than 2 audio tracks !
    If I use the option Export->Quicktime movie I can export my 6 audio tracks but I don’t want to export to .mov file…
    Can anyone confirm or has a solution ?
    Note : Using File->Export->Using quicktime conversion option, even if I select Quicktime movie or aiff file or ogg as destination format I cannot export more than 2 audio tracks.
    Thanks in advance.
    Tom
    Tom Douce replied 16 years, 5 months ago 2 Members · 2 Replies
  • Michael Gissing
    April 15, 2010 at 11:28 pm
    What are you exporting to, if not a .mov? You may have to export the audio separate to the picture but without any info as to what you are trying to end up with I can’t guess.
    Have you tried Compressor?
  • Tom Douce
    April 16, 2010 at 7:12 am
    Hi !
    I tried to export to Quicktime movie, ogg or aiff but no one let me export more than 2 audio tracks by using Menu->File->Export->Using quicktime Conversion… option.
    I need to use this option because I made my own Quicktime export plugin and I want to be able to export more than 2 audio tracks
