Activity Forums Maxon Cinema 4D Exporting mograph baked coordinates into After Effects
  • Exporting mograph baked coordinates into After Effects
    Posted by Nicolas Plaire on April 21, 2010 at 11:39 am
    Hi… I’ve got a plane that I put into a Mograph object and make it fall using gravity. Once I’m happy with the way the plane falls, I bake the fall and everything is good.
    Now when I export the rendered sequence, I don’t have a null or a solid in After Effects as reference for me to insert the graphics I wanted to add in AE. Even if I use the External Compositing Tag I usually use.
    Is there a way to import those coordinates in After Effects or should I track the plane by hand?
    Nicolas Plaire replied 16 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    April 21, 2010 at 3:27 pm
    You have to check the “cache” box in the external compositing tag. That will ensure that will give you separate tracks for each clone in AE.
  • Nicolas Plaire
    April 21, 2010 at 8:48 pm
    Gnaaaah, of course! it’s so obvious. Thanks so much! Really useful.
  • Nicolas Plaire
    April 21, 2010 at 9:19 pm
    Sorry going back to you, but the “Cache” box was already checked and I still don’t have a solid/null in After Effects… Anyway, I’ll start from here and make a few experiment to figure it out. Thanks!
  • Nicolas Plaire
    April 21, 2010 at 9:40 pm
    Sorry, I spoke too quickly. IT IS working. Thanks again.
