Activity › Forums › Adobe Premiere Pro › Exporting lossless (microsoft avi, codec = none) but Width=720 & Height=480. Why?
  • Exporting lossless (microsoft avi, codec = none) but Width=720 & Height=480. Why?
    Posted by Kevin Cotterill on July 12, 2013 at 7:44 am
    I am trying to export my sequence to a lossless file. I have chosen Microsoft AVI, codec None, however I am concerned something isn’t right.
    This is my Source Summary:
    1920×1080 (1.0), 25fps, Upper, 00:02:05:19, 48000 Hz, Stereo
    This is my Output Summary:
    720×480, 29.97 fps, Lower, Quality 100, 48000 Hz, Stereo, 16 bit
    Any help greatly appreciated. Thank you
    Tim Kolb replied 13 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Chris Tompkins
    July 12, 2013 at 10:54 am
    I would keep the fields the same, upper. I would keep the frame rate the same, 25, as well.
    What’s the end delivery? What’s the file for?
    Going to 720×480 I think you need to make the pixel aspect 1.2 for widescreen.
    Chris
  • Ann Bens
    July 12, 2013 at 11:20 am
    You are going from Pal to NTSC.
    Stick to PAL DV widescreen.
    That will give you 720×576 with a par of 1.4.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Walter Soyka
    July 12, 2013 at 2:23 pm
    These are just default settings. You can override them so they match your sequence settings. You can also create a new preset for your settings to make this a one-click operation in the future.
    Walter Soyka
  • Jeff Pulera
    July 12, 2013 at 4:16 pm
    Hi Kevin,
    When in AME, go to the VIDEO tab and scroll down until you see the settings for size, frame rate, etc. and that is where you customize.
    You might consider using the free Lagarith codec rather than uncompressed. This will be “visually lossless”. Still a large file, but certainly more manageable than uncompressed.
    Jeff Pulera
    Safe Harbor Computers
  • Walter Soyka
    July 12, 2013 at 4:31 pm
    [Jeff Pulera] “You might consider using the free Lagarith codec rather than uncompressed. This will be “visually lossless”. Still a large file, but certainly more manageable than uncompressed.”
    Lagarith is not just visually lossless, but mathematically lossless when used with RGB pixel formats. (Its YUV pixel formats are chroma-subsampled.)
    Also worth noting: Lagarith is Windows-only and may be poorly supported in other professional applications.
    Walter Soyka
  • Tim Kolb
    July 12, 2013 at 6:15 pm
    If you’re trying to save something “lossless” I assume you want to stay at the original HD frame size/rate?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Kevin Cotterill
    July 12, 2013 at 9:27 pm
    “If you’re trying to save something “lossless” I assume you want to stay at the original HD frame size/rate?”
    Yes exactly. I want a source file with max frame rate etc that I can use if I ever need to do additional renders.
  • Tim Kolb
    July 12, 2013 at 10:55 pm
    Uncompressed AVI is going to be gargantuan…I might suggest you download the free CineForm codec from GoPro for such purposes.
    When you export, you can set the framesize, etc in the video settings tab.
    TimK,
    Kolb Productions,
  • Ann Bens
    July 13, 2013 at 9:33 am
    Are you sure you can export with the free CF codec.
    Dont you need Cineform Studio Premium or simular for that.
    I can export but I think that is because I have Neoscene installed.
  • Tim Kolb
    July 13, 2013 at 12:46 pm
    Yes, once the free version is installed, you’ll find it in the export options. The key limitation is that you only have 4:2:2 10 bit HD for general use…the utility will convert GoPro 3D, but you can’t do other 3D, no 4K, no 4:4:4, etc.
    It’s still extremely useful for no cost.
    TimK,
    Kolb Productions,
