Activity › Forums › Apple Final Cut Pro Legacy › Exporting letterboxed DV NTSC as 16×9
  • Steve Eisen
    December 21, 2008 at 2:49 pm
    Do not manipulate your footage. Just change the TV to wide screen from normal.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Andy Mees
    December 21, 2008 at 3:53 pm
    I’d agree with Steve. Chances are good that a 16:9 TV will have a zoom mode for displaying letterboxed images as full screen.
    That said, not all of them do, so if you do really want or need to export as 16:9 then you can easily do this in Compressor’s Geometry controls by setting the Source Inset (Cropping) Crop to control to 16×9 1.78:1
  • Kevin Monahan
    December 21, 2008 at 6:45 pm
    Any kind of zooming into a 4:3 letterbox will be degraded compared with a widescreen version of the field, no?
    I prefer to make a widescreen sequence and let the DVD letterbox for 4:3 TVs.
    I copy/paste the clips into a 16:9 sequence, then change the distortion for one. I copy/paste attributes to the other clips and make any other adjustments for non-standard clips. Done.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Alexander Kallas
    December 21, 2008 at 10:36 pm
    [Andy Mees] “I’d agree with Steve. Chances are good that a 16:9 TV will have a zoom mode for displaying letterboxed images as full screen.
    With either of the above, you will have scaling problems and as the source is DV, resolution loss also.
    Cheers
    Alexander
  • Andy Mees
    December 22, 2008 at 12:07 am
    snore
  • Kevin Monahan
    December 22, 2008 at 6:00 pm
    There is a lot more scaling in a letterboxed sequence than just a horizontal squeeze with anamorphic footage.
    Kevin Monahan
