Activity Forums Adobe Premiere Pro Exporting Large Files as AVI
  • Exporting Large Files as AVI
    Posted by Steven Pritchard on August 7, 2008 at 10:59 am
    Hi,I asked this question a few months ago but the project I was working on fell through. Is it possible to export a project file larger than 2gb or approx 20 minutes long as an AVI file? I use Premier Pro 2.
    Derek Lau replied 18 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Mike Velte
    August 7, 2008 at 1:09 pm
    Microsoft DV.AVI and Microsoft AVI with no compression can exceed 4 GB, although there are few good reasons to do either…why do you want to?
  • Terry Gipson
    August 7, 2008 at 1:37 pm
    I may be off here because I’ve only done a few projects so far in PProCS3, editing several events with large sequences (over 1 hour). I am not sure I like the quality of the direct-to-DVD workflow result thru PProCS3 as well as my old way of DVD production, exporting the uncompressed sequence from the NLE and then rendering to mpeg2 DVD format with TPMGEnc. I did this with Avid Liquid and was happy with the result.
    I am still experimenting with the DVD production thru PProCS3, but I regularly export large sequences >20GB uncompressed without problems.
    Fumbling my way happily thru the world of HD…
  • Harm Millaard
    August 7, 2008 at 2:08 pm
    Yeah.
    Harm Millaard
  • Steven Pritchard
    August 7, 2008 at 10:35 pm
    I shot a work conference that runs 60 minutes but when I try to export it as a movie file that I can then burn to DVD I get an error message that the scratch disk is full. Surely there are others who have projects that run over 10 minutes that need to be exported the same as I’m trying to do.
  • Steven L. gotz
    August 8, 2008 at 12:29 am
    Sure, but don’t try using a FAT32 drive. You need to export to an NTFS drive to go over 2GB. And your cache drives must be NTFS as well. And have lots of room left on them.
    Steven
    https://www.stevengotz.com
  • Steven Pritchard
    August 8, 2008 at 2:39 am
    Steve, thanks for the advice. Much appreciated.
  • Derek Lau
    August 8, 2008 at 5:08 pm
    just to add to the drive info…. most drives can be fat 32 or NTFS, you just have to format them to be one or the other…… this is always a good thing to do as soon as you get the drive, before you fill it with tons of stuff as a fat32….
