Exporting issues
I use Final Cut Pro 7.0.3 version on my MacBook Pro. I filmed some footage with Canon 5d Mark3, 1920×1080 25fps (PAL), and after editing if I use any effect, say cross dissolve, it doesn’t work when I play back after exporting. On the timeline it works, but I do have some issues when rendering. I need to render small bits, if I try to render the whole thing, about 4minutes of footage, the FCP crushes and gives an error message saying there is a problem with the Perian plug-in…
After exporting, the parts where I applied an effect (cross dissolve) it doesn’t show a dissolve, but it freezes the frame for a second and just jumps to the next frame. There is the same problem if I try to make the cross dissolve without effects, just using the rubber band and manually making the fade-out/fade-in on the timeline.
If I export the same thing without any effects, there’s no problem.
