Activity Forums Adobe After Effects exporting individual layers/movies?
  • exporting individual layers/movies?
    Posted by Bobby Mosaedi on January 31, 2006 at 11:20 pm
    is there a way to export out of AE each individual layer as its own movie? or to maybe create precomps and export the precomps? i have an edit system that will play animation files with alpha in real-time, so being able to export each layer (for smaller compositions) would help tremendously.
    Bobby Mosaedi replied 20 years, 7 months ago 3 Members · 3 Replies
  • Chuckwagon524
    January 31, 2006 at 11:46 pm
    No way to do what u want in one swoop but here is what you could do. Select the layers u want to precomp. Go to layer> precompose. In the dialogue box,one precomps everything, one does the layers only.
    you could also duplicate the comp in the project window several times (apple+D/cntrl+D). Open up those duped comps (I suggest renaming 1st), and either turn off the visability or delete the layer you don’t want shown. Then que them up to render.
  • Jeff Almasol
    January 31, 2006 at 11:47 pm
    If you’re using AE 7, one solution is to use my rd: Render Layers script for rendering selected layers separately. You can find it here:
    https://www.redefinery.com/ae/view.php?item=rd_RenderLayers
    Jeff
  • Bobby Mosaedi
    February 4, 2006 at 9:37 pm
    what exactly is prerender?
