Activity › Forums › Adobe Premiere Pro › Exporting individual clips
  • Exporting individual clips
    Posted by John Brookhouse on September 23, 2009 at 7:59 pm
    I have a 10 minute video that I need to pull a bunch of 10 second files out of. Is there some way to tell Premiere Pro/Encoder to create a separate file out of each clip on a timeline in lieu of one long file that includes all of them?
    Thanks in advance for your help!
    John
    John Brookhouse replied 17 years ago 2 Members · 2 Replies
  • Mike Velte
    September 24, 2009 at 10:43 am
    Well sort of…for CS4 only
    Put your 10 min clip into the source window. Select in/out points for the first 10 second clip and insert that to an empty sequence. File>Export>Media
    Choose your export settings and click OK sending that sequence to the Encoder Que.
    File>New>Sequence
    Repeat the above steps 9 more times.
    When done fire up the encoder.
  • John Brookhouse
    September 24, 2009 at 4:57 pm
    Thanks for the info! That’s actually the way that I’ve been doing it, but it’s a lot of extra steps. I was just hoping for some check mark I could make to tell Encoder and/or Premiere Pro to treat each clip as it’s own file.
    Thanks again!
