Activity Forums Apple Final Cut Pro Legacy Exporting in Uncompressed
  • Exporting in Uncompressed
    Posted by Stephen Lubin on February 23, 2010 at 2:53 am
    Hello!
    I’ having problems exporting in an uncompressed format. I’m required to have it completely uncompressed and when I do that, the color on the image is slightly different.
    I’ve rendered the video in ProRes 1080p 30 fps via file > export > quicktime movie. That looks fine, but obviously not uncompressed
    I then went to file > export > quicktime movie > settings > custom. I then put frame size as 1920 x 1080, pixel aspect ratio square, field dominance as none, and compressor as none with quality at 100%. Yet somehow when it exports, it looks different.
    Am I doing anything wrong? Thanks in advance!!
    Jeremy Garchow replied 16 years, 7 months ago 3 Members · 4 Replies
  • David Roth weiss
    February 23, 2010 at 3:27 am
    [Stephen Lubin] “I then put frame size as 1920 x 1080, pixel aspect ratio square, field dominance as none, and compressor as none with quality at 100%. Yet somehow when it exports, it looks different. “
    “None” is a so-called legacy codec, with no benefits whatsoever, but with numerous issues, such as the color space issue you’ve encountered. Use 8 or 10-bit uncompressed instead and you should not encounter the same problem.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Stephen Lubin
    February 23, 2010 at 4:05 am
    Thank you very much sir! Worked like a charm!!
    -Stephen
  • David Roth weiss
    February 23, 2010 at 4:12 am
    You’re very welcome Stephen. It’s always good to hear back when things work.
    THNX,
    David
    David Roth Weiss
    Los Angeles
  • Jeremy Garchow
    February 23, 2010 at 1:42 pm
    You could also use Compressor for this. QT Conversion can be weird.
