Activity › Forums › Apple Final Cut Pro Legacy › exporting in fcp
  • Shane Ross
    May 12, 2009 at 10:00 pm
    WOW! Looks pretty. I like the music.
    But I have never seen this happen. Does this happen if you export a Quicktime Movie…self contained?
    Shane
  • John Fishback
    May 12, 2009 at 10:01 pm
    What are your settings? What kind of system setup, etc? What codec is your source and what is your export codec?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Zane Barker
    May 12, 2009 at 10:02 pm
    [Ryan Heckman] “Is there something wrong in my settings”
    Cant say because you did not tell us what you settings are.
    [Ryan Heckman] “do I need to update something? “
    Again we cant say because you did not tell us what version you are on.
    First off how are you exporting the video?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Ryan Heckman
    May 13, 2009 at 12:19 am
    I am not sure. I am exporting right now again self-contained
  • David Peralta
    May 13, 2009 at 12:26 am
    The few times ive seen a video play out like that was when my hard drives gave out and corrupted the video files. Or if your playing it over a network connection and the drives are suddenly disconnected without a proper unmount.
    hmm… I wonder what this button does…
  • Ryan Heckman
    May 13, 2009 at 12:38 am
    I have fcp 6.
    And im exporting file-export-quicktime movie.
    I don’t really know all the complex settings…
  • Ryan Heckman
    So are you saying maybe the footage I used is corrupted?
  • Rafael Amador
    May 13, 2009 at 9:38 am
    This similar to what I was getting when trying to export any 10b from Shake. Random color noise.
    (Only recently have been fixed)
    There is something broken in QT.
    The compression or decompression doesn’t works.
    I would start by re-installing the last update.
    You say that you have this problem when exporting from FC.
    And when you export from QT?
    The truth is that you didn’t give many details.
    BTW, I would keep some of those clips for using as backgrounds or so.
    rafael
    http://www.nagavideo.com
  • Ryan Heckman
    May 13, 2009 at 12:35 pm
    Thank you for your response Rafael, im very sorry I didn’t give much information, I dont know much about the settings that im using…but I did find out that the video files I was using were corrupted which was why it turned out like that. But also I am going to re-install my last update. Thank you very much for the advice and for the help. – Reese
  • Rafael Amador
    May 13, 2009 at 1:11 pm
    [Ryan Heckman] “And im exporting file-export-quicktime movie. “
    Hi Ryan,
    What I was asking you is who QT works.
    FC mke this, but try to open a QT file with QT player and export to any other codec. Not with FC.
    Another question was about the codec you were working with and to which codec you were trying to export.
    I’m not sure the files are corrupted. What I see is that they are not properly exported, displayed or whatever.
    Corrupted files normally you can not even open them and may even make crash any application
    Rafael
