Activity Forums Adobe After Effects Exporting in DVCPRO HD 720
  • Exporting in DVCPRO HD 720
    Posted by Hunter Hempen on April 30, 2010 at 11:50 pm
    As displayed in the title, I am working with some footage from my campus’s video services department that requires to be imported in DVCPRO HD 720 23.03789879879879787 fps etc etc. The problem is, once the footage is imported and appears on the preview screen under the correct settings, these vertical lines appear in the footage, almost like un-interlaced footage…but those are always horizontal when I see them.
    When I render the footage as a Quick-time file, however, the vertical lines disappear in the final file, but the frame is squished to 4:3 instead of 16:9…this I don’t know how to fix. When this 4:3 is imported into Premiere, however, it goes back to regular wide-screen as if nothing happened. What the hell is going on here??
    Hunter
    Greg Robbins replied 16 years, 4 months ago 2 Members · 2 Replies
  • Hunter Hempen
    April 30, 2010 at 11:53 pm
    Correct me on “un-interlaced” footage, I don’t think that’s the correct term. Maybe just interlaced. Wrong nounage.
  • Greg Robbins
    May 2, 2010 at 4:53 am
    The squashing of the video is because of the PAR (pixel aspect ratio). After Effects displays all footage in square pixels until you click the correct pixel aspect ratio button the on bottom of the comp window. Then it will display properly if using non square pixels. Premiere reads the PAR when it reads the video file and displays it properly. I recommend you read up on pixel aspect ratios. A quick google search should point you in the right direction.
