Activity › Forums › Adobe Premiere Pro › Exporting in 16 x 9 with Premiere 1.5
Posted by Dylan O’leary on August 21, 2006 at 6:25 pmI’m trying to export to DVD in Adobe Premiere 1.5, but the DVD won’t hold the aspect ratio at 16×9 when played on a TV. Any clues?
Dylan O’Leary
http://www.scoutsthemovie.comJeff Bellune replied 20 years, 1 month ago 5 Members · 7 Replies -
Blast1
August 21, 2006 at 7:21 pm[Dylan O’Leary] “DVD won’t hold the aspect ratio at 16×9 when played on a TV.”
What kind of TV SD or WS, I assume WS, whats it doing, pillar boxing?
Dex Craig
August 21, 2006 at 7:30 pmI produced a feature-length movie using Premiere 1.5 in 16×9 without any trouble. Where I had trouble was with the DVD authoring software. Adobe Encore 1.5 was perfect; I’d tried using some other DVD packages and would wind up with 16:9 squished to 4:3.
What software are you encoding the DVD with?
Blast1
August 22, 2006 at 6:23 amI was using Encore 1.5, I’ve got 2 now but haven’t used it yet, I’ve done a bunch simple projects in Ppro 2 where I could just use its DVD templates and photoshop.
Ervin Farkas
August 22, 2006 at 2:18 pmI scratched my head over this same issue just a few weeks ago. To further complicate things, the authored DVD (Encore) looked 16×9 on the PC but full screen on my TV. Turned out, I had my Philips DVD player set wrong…
Ervin
Dylan O’leary
August 22, 2006 at 3:32 pmnaw, it’s just expaning to fill the 4:3, so the sides get cut off. It’s a normal (4:3) TV.
Dylan O’Leary
http://www.scoutsthemovie.com -
Dylan O’leary
August 22, 2006 at 3:33 pmI’m using just the Adobe Premiere program to export to DVD. I’ll try exporting as MPEG2 then burning it to DVD. More soon.
Dylan O’Leary
Jeff Bellune
August 23, 2006 at 1:54 amCheck the player’s settings. They should be set to 4:3 Letterbox.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
