Activity Forums Apple Final Cut Pro Legacy Exporting Images to use on Web
  • Exporting Images to use on Web
    Posted by Chris L. on June 7, 2005 at 3:29 pm
    I want to pull images off my video to use on my website. I have had some success, but some images are slightly blury (they have lines thru them as if the scan rate or fps is off). Does anyone have solutions for me to get the best quality results?
    Erichindes replied 21 years, 2 months ago 3 Members · 2 Replies
  • John Treffer
    June 7, 2005 at 3:41 pm
    It sounds like interlacing problem.
    Apply a deinterlace filter to the image, either in fcp to the clip before export or in photoshop or GIMP after you exported the image.
  • Erichindes
    June 7, 2005 at 3:47 pm
    Are you seeing interlacing? Sounds like you need to import it into Photoshop and apply the de-interlace filter:
    FILTER > VIDEO > DE-INTERLACE
