Activity Forums Adobe Photoshop exporting images for NTSC
  • exporting images for NTSC
    Posted by Judita on July 19, 2007 at 4:28 pm
    What are the steps to create and save a .png file so that it will correctly import into a non-linear editor (NTSC video) with the correct aspect ratio?
    I’m trying to get my head around the square/non-square pixel problem, and not succeeding… 😉
    I import into my video app at 720×540.
    Richard Harrington replied 19 years, 1 month ago 3 Members · 2 Replies
  • Darby Edelen
    July 19, 2007 at 6:58 pm
    [Judy Ranelli] “I import into my video app at 720×540.”
    The resolution of NTSC DV is 720×480 (D1 is 720×486).
    If you’re using 720×540 PNGs then you want to make sure that they do not use pixel aspect ratio correction in Photoshop.
    When you bring your Square Pixel 720×540 image into an NLE you will then need to fit it to the Sequence/Composition/Timeline’s NTSC resolution, in effect squashing your 720×540 image down to 720×480 and giving it the proper pixel aspect ratio to be correctly interpreted on a standard NTSC device.
    Most programs have a function to fit footage to the correct resolution.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Richard Harrington
    August 3, 2007 at 1:03 am
    There’s A LOT more to this….
    Start here
    https://www.photoshopforvideo.com/blog/files/psvpresets.html
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
