Activity Forums Adobe After Effects exporting image sequence with transparency.
  • exporting image sequence with transparency.
    Posted by Anita Sancha on September 6, 2008 at 10:17 am
    Hi.. all
    ideally taga … have tried millions colors+ but still exporting with black background.
    At the moment I am exporting to psd every frame as stills…. taking ages.
    Thanks anita.
    Anita Sancha replied 17 years, 8 months ago 2 Members · 2 Replies
  • Simon Bonner
    September 6, 2008 at 12:18 pm
    1: Add the comp to the render queue
    2: Click on the link to the right of the output module (Lossless by default).
    3: In the Output Module Settings dialogue, click on the topmost dropdown menu (format) and choose png sequence.
    4: Change the Channels drop down menu from RGB to RGB + Alpha. In case you don’t know, the alpha channel is where the transparency info is kept.
    5: Render and you’re done.
    I see you want to export a targa sequence. I don’t know if this works as I normally just use png, so feel free to try this with targa.
    Simon Bonner
    youtube.com/simonsaysFX
  • Anita Sancha
    September 7, 2008 at 7:15 am
    thanks thats great. just what i needed.
