Activity Forums Adobe After Effects Exporting Holometrix
  • Exporting Holometrix
    Posted by James Gordon on November 29, 2011 at 6:19 am
    Hi – I’m new to AE and the holomatrix plugin. When I view a holomatrix layer over a video layer in AE, it’s a semi transparent “hologram”. When I export just the hologram layer to another program (FCP) using animation – 1 million +, the “hologram” is no longer semi transparent. I can reduce the opacity in FCP but then I loose a lot of the bright glow I’m seeing in AE. Is this just the way it is or am I making a new guy error when exporting? Thanks for this forum.
    James Gordon replied 14 years, 9 months ago 3 Members · 4 Replies
  • John Cuevas
    November 29, 2011 at 2:52 pm
    I don’t have Holometrix, but in your render Output Module have you changed your Channels to “RGB + Alpha” and your format to something supports an alpha, like Quicktime Animation or PNG?
    Johnny Cuevas, Editor
    Thinkck.com
  • James Gordon
    November 29, 2011 at 3:31 pm
    Thanks for responding. Yes, I’ve exported with an alpha channel. The area around the hologram is transparent. My issue is that I’m losing the semi transparency in the “hologram”.
  • Walter Soyka
    November 29, 2011 at 3:37 pm
    [James Gordon] “Yes, I’ve exported with an alpha channel. The area around the hologram is transparent. My issue is that I’m losing the semi transparency in the “hologram”.”
    Perhaps you have a mismatch in alpha intepretation? Have you exported premultiplied alpha when FCP is expecting straight?
    See Alpha channel interpretation: premultiplied or straight (AE) [link] and Working with Clips That Have Alpha Channels (FCP) [link].
    Walter Soyka
  • James Gordon
    November 30, 2011 at 1:03 am
    Thanks for the links. I’ll check them out. I actually exported both a straight and a matted (premultipled) version just to see if that was it. In both versions, the area around the “hologram” is transparent but the hologram has lost it’s semi transparency and is 100% opaque.
    One thing I’m just now realizing In AE, when I turn off the visibility of the layer below the “hologram”, that’s when the hologram loses its semi transparency. Before it’s even rendered.
    With mo layer below it, it’s 100% opaque. So it doesn’t seem to be a rendering issue. Again, I’m really new to AE and Holomatrix, but might holometrix be creating, or precomping, it’s semi transparency for the “hologram” based on the layer below?
    Thanks again for your time and thoughts.
    Has anyone viewing this post successfully rendered a holometrix layer by itself, with it’s partial opacity intact?
