Activity › Forums › Adobe Premiere Pro › Exporting HDV to WMV
Posted by Amit Zinman on April 5, 2005 at 5:11 pmEveryone says Windows Media is the way to go when exporting HDV material. I’ve tried various tools but haven’t the right settings for this. Can anyone post the tool used and the exact settings?
Also, I would appreciate a screen capture (always simplest).Thanks,
Amit
Steven L. gotz replied 21 years, 5 months ago 2 Members · 5 Replies -
Steven L. gotz
April 5, 2005 at 8:56 pmVarious tools? I use the Adobe Media Encoder just like I did with DV.
What is your ultimate goal? Where are you playing the video?
I play mine on my AVeL Linkplayer2 and generally export to a 8Mbps stream. If I was going to play it on a PC, I would probably use 5Mbps.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro
https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Amit Zinman
April 6, 2005 at 2:12 amI am trying to distribute my HDV short film which was shot in 1080i PAL.
I tried using Adobe Media Encoder but even using the highest settings it just gives wavey fuzzy results. -
Steven L. gotz
April 6, 2005 at 3:43 amDistribute it how? Play it back on what? Which settings? Did you deinterlace?
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Amit Zinman
April 6, 2005 at 9:59 amDistribute via CD, playback on a computer screen,and no I did not interlace as I could not find such a setting for Windows Media export.
Steven L. gotz
April 6, 2005 at 1:44 pmVia CD I would probably encode at 1280X720 – at around 5Mbps max, and Deinterlace is one of the pre-encoding tasks in the Adobe Media Encoder.
Steven
