Activity › Forums › Adobe Premiere Pro › Exporting HDV to H.264 codec
  • Exporting HDV to H.264 codec
    Posted by Tom Sefton on July 22, 2008 at 9:15 am
    Hi guys,
    I have seen some amazing quality HD clips that have been exported using H.264 codec within Premiere Pro and I can’t seem to get any good results at all!
    Video is very pixellated, grainy and very washed out.
    I am running a quad core HP machine with windows, 4GB RAM and Premiere Pro 2.
    Mike Velte replied 18 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Mike Velte
    July 22, 2008 at 11:24 am
    1. What are your Project Settings?
    2. What are the Properties of your HDV video?
    3. What are your export settings?
  • Tom Sefton
    July 22, 2008 at 11:41 am
    Project settings = Matrox HDV 1080i @25fps
    1440 X 1080
    HD anamorphic
    Upper Field First
    HDV properties – HDV video 1080i anamorphic shot with Canon XL-H1
    export settings
    Format – Quicktime
    Video Codec – H.264 encoder
    W – 1440
    H – 1080
    Frame rate – same as source
    Field order – upper
    Aspect Ratio – 1080 Anamorphic
    Bit Depth – 24 Bit-colour
    Bitrate – tried various settings to no difference – but say 10 mps
    Key frame distance – 1 frame
  • Mike Velte
    July 22, 2008 at 12:25 pm
    [Tom Sefton] “Bitrate – tried various settings to no difference – but say 10 mps”
    10 Mbps is about half of what it should be. Try VBR 2 pass, Target=20Mbps, Max =25.
  • Tom Sefton
    July 22, 2008 at 1:37 pm
    I dont have the option of encoding with 2 pass VBR whilst in QT and H.264 codec – any ideas why?
  • Dustin Brown
    July 22, 2008 at 4:15 pm
    As far as it being washed out, once you have the video exported, open it in QT Pro, Window > Show Movie Properties. Select the Video Track. Go in the Visual Settings tab. Set your Transparency mode to Straight Alpha in the drop down. Save your file.
    -Dustin
  • Mike Velte
    July 22, 2008 at 6:31 pm
    In the Adobe Media Encoder, choose H.264 as the Format and “HDTV 1080p 25 High Quality” as the Preset…that is 32 Mbps, 2 pass VBR.
  • Tom Sefton
    July 23, 2008 at 9:27 am
    I don’t have those options – I am running Premiere Pro 2 – is this why? I am assuming that H.264 encoding is something that CS3 can do as standard, but Prem 2 won’t…..
    When I run Adobe or Matrox encoder, I can define that I want to encode in Quicktime, but there are minimal presets that you would use within here. I have to specify within the video settings that I want to use the H.264 codec, not Sorensen.
  • Mike Velte
    July 23, 2008 at 10:30 am
    [Tom Sefton] “I am running Premiere Pro 2 – is this why?”
    Yes
    Other good options;
    QT Pro $30
    Mainconcept Mpeg Pro plug-in $399
