Activity › Forums › Apple Final Cut Pro Legacy › Exporting HDV sequence for DVD
  • Exporting HDV sequence for DVD
    Posted by Ed Singleton on March 22, 2008 at 2:40 pm
    Hi Everyone.. (Newbie technophobe here).
    Might sound a simple task to you guys but I’m having trouble exporting a HDV sequence to Quicktime movie. (Best possible resolution) to burn onto an SD DVD (PAL). My Sequence settings I think are correct: (See below). I think the footage was initially digitized into FCP at the wrong frame size 1440×1088 from a Sony Z1. Should it have been 1920×1080 as someone has said?
    I was wondering if this could be part of my problem and could/should I resize the clips in the sequence to 1920×1880 and if so how would that be done?
    Sorry for being such a numbskull, but any help or advice on a” step by step” process through the settings and export would be greatly appreciated to a beginner editor. No amount of lnstruction-reading has seen me succeed and I’m beginning to lose heart.
    Either way, this is a great forum and a mine of useful information to all using FCP. Keep up the great work
    Best regards.
    Ed. Liverpool .UK
    GENERAL TAB =
    Frame size 1920×1080. Aspect Ratio = HDTV 1080i-50
    Pixel Aspect Square
    Field Dom =Upper
    Quality 100%
    VIDEO PROCESSING TAB =Checked
    Render 10bit material Hi Pres YUV.
    Process Max White as = White
    Motion Filtering Quality = Best
    Ed Singleton replied 18 years, 6 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    March 22, 2008 at 9:38 pm
    The size you have is correct.
    Just export the finished sequence directly to Compressor for the MPEG-2 compression.
    It’s likely to take a long time to compress, and if you want to speed up the process, you could export the sequence as a DVCPROHD Or DVCPRO50 QT and compress that… but theory would state a double compression isn’t as good, but it may be acceptable, and it’s likely to be faster.
    I’d just export the native sequence myself, and take a powder..
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ed Singleton
    March 26, 2008 at 12:02 pm
    Thanks for that Jerry..
    Will attempt to export the sequence as advised.
    Much appreciated.
    Eddie Singleton.
  • Ed Singleton
    March 26, 2008 at 12:03 pm
    Much appreciated.
    Eddie Singleton.
