Activity › Forums › Apple Final Cut Pro Legacy › Exporting HD to DVD isn’t playing smoothly
Posted by Robert Sherwood on October 19, 2009 at 2:38 amI am trying to export my HD foots to a dvd the foots plays smoothly when i export it to the mac but when its on dvd the slow mo is very edgy and the video doesn’t run smooth..
Its shot in PAL 25fps i really need it working as i plan to distribute this surfing movie very soon.
Hope someone can help! Thanks.
Robert Sherwood
John Fishbackreplied 16 years, 11 months ago 3 Members · 6 Replies
Richard Harrington
October 19, 2009 at 4:20 amYou need to author a DVD or create a Blu-ray disc. You can’t just copy footage to optical media and expect it to play back smoothly.
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
John Fishback
October 19, 2009 at 8:00 pmExport a Self-contained, Current Settings QT movie, do not use QT Conversion. Bring this file into Compressor and use the DVD Best Quality 90 Minute setting: one for video (mv2) and one for audio (ac3). For the ac3 setting change the Compression Preset from Film Standard to None and Dialog Normalization from -27 dbFS to -31 dbFS. When Compressor finishes the encode, start DVD Studio Pro and import both files. Drag them into a Track, set the track for First Play and adjust the track parameters for Display Mode: 16×9 Letterbox. Then Build/Format the DVD. For more detail, search the Cow and you’ll find it.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Robert Sherwood
October 19, 2009 at 11:23 pmThanks for the help John. I’ll try this out and let you know how i go.
Also.. Have you been able to put a Drop Shadow on a clip you have slowed down to make it play smoother on FCP?Robert Sherwood
Robert Sherwood
October 20, 2009 at 1:11 amI did everything as you did but must have gone wrong somewhere along the way.. I burnt the dvd but it says unknown disc when i put it in. Any suggestions?
Robert Sherwood
John Fishback
October 21, 2009 at 9:34 pmHow did you make the DVD? That error is strange.
John
