Activity Forums Apple Final Cut Pro Legacy exporting HD sequences
  • exporting HD sequences
    Posted by Ryan Howard on January 24, 2008 at 11:24 pm
    Hello,
    Whenever I try to export an HD sequence using Quicktime conversion, it squishes the video into a square format. I’ve tried exporting for broadband and for Ipod, and it always does the same thing. Any thoughts?
    Ryan
    Dustin Parsons replied 18 years, 7 months ago 2 Members · 1 Reply
  • Dustin Parsons
    January 25, 2008 at 1:49 am
    After going into the Quicktime Conversion window click on the Options… button next to Format. Within the options window check and make sure the Size is the correct aspect ratio that you want to export to.
    I’m pretty sure the broadband and ipod settings you chose affect the codex/compression only, not the aspect ratio.
