Activity Forums Adobe After Effects Exporting HD MPEG with Audio as 1 file??
  • Exporting HD MPEG with Audio as 1 file??
    Posted by Will Gaffney on September 12, 2008 at 1:59 am
    I imported the original HDV files into After Effects CS3, and applied all the required filters etc.
    Now I want to export the footage as a HD Mpeg (because the quality is good but the size is smaller than MOV or AVI) and then open my Premiere project and link all footage to the new graded files.
    The problem I have is the Original files captured from the tapes are MPEG’s with the audio attached where the AE export is an MPEG video file with WAV Audio as a seperate file. This means when I try click “Link Media” in PPro the files cant be replaced because they dont match.
    Does anyone know a way to export from AE as a 1440×1080 MPEG with the audio actually a part of the file and not a separate WAV??
    Will Gaffney replied 18 years ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    September 12, 2008 at 1:25 pm
    Havent done this in a while. But look for a radiobox/button that allows to to set multiplex on and off. Multiplexed files have both audio and video as a single file.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Will Gaffney
    September 12, 2008 at 1:44 pm
    Thanks for your response Dave.
    As I have only applied filters and effects via adjustments layers in AE, I could import the video files as a different format if I convert them first and then export again.
    Do you have any suggestions?
    Should I convert the MPEG into another format then import into AE?
    Will this solve my High-Res, Small size, single video/audio file dilemma?
    Cheers
    Will
  • Will Gaffney
    September 15, 2008 at 2:28 am
    When I select “Add to render queue” in the export settings I can select to multiplex the video and audio however when I click this, then click render, it errors out and wont let me render the file.
    Is there any other options?? Anything at all???
