Activity Forums Adobe Premiere Pro Exporting HD in Premiere Pro
  • Exporting HD in Premiere Pro
    Posted by Adam Sorbin on August 7, 2010 at 5:00 pm
    Hi all,
    I’ve read on the Adobe Help site https://livedocs.adobe.com/en_US/PremierePro/3.0/help.html?content=WSCE52A514-41FD-4585-967E-BAA41ED9C380.html that Premiere Pro CS3 does not export into HD unless I have an HD capture card.
    “If you have a supported high-definition capture card installed, you can export high-definition sequences to a high-definition file format on hard disk or to tape in a high-definition device. ”
    I am looking to export an HD Sequence in Quicktime .MOV format (1440 x 1080), what exactly does a “High Definition Capture card” mean?
    I have an ATI Radeon HD 5450, running Windows XP, Adobe CS3 Suite (and Sony Vegas Pro 8) on an AMD Quad-Core machine.
    Please help!
    Pete Burger replied 16 years, 1 month ago 2 Members · 1 Reply
  • Pete Burger
    August 16, 2010 at 8:15 am
    AFAIK you can’t export to an HD-Codec with CS3 with the standard installation. But you can export via Media Encoder as Quicktime with all of the parameters(frame width/height, codec etc.)set to your liking and then compress the video with a different application like SUPER. I haven’t tried it, but I read something about installing some Decklink (Blackmagic design) drivers, even if you don’t have the proper hardware installed and then being able to export true HD. Don’t know if that works…
