Activity › Forums › Adobe Premiere Pro › Exporting – hang up in frames
  • Kris Merkel
    January 6, 2012 at 7:29 pm
    What bit rate are you using for your compression? I would start troubleshooting by taking a smal 10 sec clip of the area that looks the worst and play around with your compression settings.
  • Jeff Pulera
    January 6, 2012 at 7:46 pm
    Make sure that the frame rate of your edit sequence matches the footage. Looks like there are interpolated frames in there. Frame rate should be consistent through entire workflow
    Jeff Pulera
    Safe Harbor Computers
  • Morten Engelien
    January 12, 2012 at 3:34 pm
    Thanks for the fast reply!
    I found i found the soluting to my problem. NeatVideo! When i uninstalled neatvideo, it worked fine:)
