Activity › Forums › Adobe Premiere Pro › Exporting H264 with TC Ref for mix is not frame accurate
  • Exporting H264 with TC Ref for mix is not frame accurate
    Posted by Joseph Hung on July 30, 2014 at 8:51 pm
    Hello fellow cows,
    I’ve done some googling and have not been able to pinpoint this specific problem.
    When I export a reference video for my audio mixer to use as a frame accurate, with timecode burned in (no offest or anything out of the ordinary), and a 2 pop/beep, the resulting video is not frame accurate.
    Example: I ahve a ProRes 4444 timeline and assets. 29.97, 1920×1080, non drop timecode, 48/24 audio. My countdown and 2 beep is exact, the 2 and beep is right on 00:59:58:00, and program starts on the hour. I usually give the full 10 second countdown, but in this case it doesn’t matter, but I always give at the very least a 2 beep with the video. I export a Quicktime .mov H.264, smaller resolution, same framerate, same audio setting (48 khz) etc. The resulting video that gets spit out always has about a 2/3 of a frame of silence before the 2 beep, which then sets everything off down the line by 2/3 of a frame. The TC ref on the video still says 00:59:58:00 though, and when I bring it in to line up with the ProRes 4444 timeline, you can see the offset. My audio mixer (in ProTools) has found that it’s about a 513 sample difference.
    Why is this? It’s only when I’m encoding to a compressed codec like H264 (either .mov or .mp4). it’s usually .mov for me since ProTools seems not to like .mp4. And when I do a test by exporting native codec prores 4444, it lines up perfectly, with no offset.
    Is there a work around for this? Here is a screengrab of the 2 beeps so you can see the offset.
    Joseph
    work.tulpapictures.com
    Twitter/Vimeo/Facebook: @TulpaPictures
    Mac Pro 2.4GHz 12 Core Intel Xeon (5,1) 32GB RAM
    Macbook Pro 2.3 GHz Intel Core i7 (8,2) 4 GB RAM
    OSX 10.8.5
    Adobe CC
    FCS3
    Davinci Resolve
    AJA Kona LHi/Blackmagic
    MSI Twin Frozr GeForce GTX 680 4GB GPU
    EVGA GeForce GT 640 4GB GUI
    RocketRAID 4322 SAS
    ProAvio 8TB RAID5 SAS
    Own Cams: BMCC 2.5K EF, GH3, Hacked GH2, 5DMKII
    Joseph Hung replied 12 years, 1 month ago 1 Member · 1 Reply
  • Joseph Hung
    August 3, 2014 at 5:09 pm
    It appears that this is not discussed that widely, but I did find some threads of problems that have the same symptoms. Anyways, it’s the AAC encoding, and here’s the white paper about the encoder delay and synchronization. Hope this helps people out.
    Technical Note TN2258: AAC Audio – Encoder Delay and Synchronization
    OSX 10.8.5
    Adobe CC
    FCS3
    Davinci Resolve
    RocketRAID 4322 SAS
