Activity Forums Apple Final Cut Pro Exporting H.264 Using High Quality Profile
  • Exporting H.264 Using High Quality Profile
    Posted by Bryan Mullennix on January 30, 2014 at 6:11 pm
    I have the need to export some footage into the h.264 codec and need to do so in the High Quality profile. Apparently FCPX and Compressor don’t have the option for the High Quality profile. I could export a master pro res file and then run it through another media encoder. So the question is there a high quality but inexpensive media encoder that offers the h.264 high quality profile?
    Dave Gage replied 12 years, 7 months ago 5 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    January 30, 2014 at 6:46 pm
    Compressor 4.1 now offers High Quality profile and two different entropy settings.
    Jeremy
  • Bryan Mullennix
    January 30, 2014 at 7:18 pm
    Thanks Jeremy! I’m not seeing the ability to upgrade from Compressor 4.0 to 4.1 in the Mac app store. Is this an issue where I need to upgrade to the new Mavericks operating system in order to get this upgrade?
  • Jeremy Garchow
    January 30, 2014 at 7:21 pm
    [Bryan Mullennix] “Thanks Jeremy! I’m not seeing the ability to upgrade from Compressor 4.0 to 4.1 in the Mac app store. Is this an issue where I need to upgrade to the new Mavericks operating system in order to get this upgrade?”
    Correct, sir. FCPX 10.1, Compressor 4.1, and Motion 5.1.
    Jeremy
  • Bryan Mullennix
    January 30, 2014 at 7:54 pm
    Thank you!
  • Bernhard G.
    January 31, 2014 at 8:48 am
    Hello,
    you should give HandBrake a try.
    https://handbrake.fr
    It is Open Source, reads all ProRes types, uses Lanczos for scaling,
    does motion-compensated De-Interlacing (“slower” setting), has Noise-Filtering,
    and codes with x264, the best H.264 encoder.
    Best regards,
    Bernhard
  • Jeremy Garchow
    January 31, 2014 at 3:07 pm
    Handbrake is great. I use it a lot.
    The only problem is that it’s not plugged in right to FCPX, so you have to essentially export twice, once out of fcpx and once out of handbrake.
    It is a pretty good encoder, though.
    Jeremy
  • Bernhard G.
    January 31, 2014 at 5:03 pm
    [Jeremy Garchow] “The only problem is that it’s not plugged in right to FCPX, so you have to essentially export twice, once out of fcpx and once out of handbrake.
    Yes this is true. But as long as FCP-X consolidates everything to ProRes under the hood, the export at least is fast and causes no loss in quality.
    I would really appreciate if Apple would integrate OpenCL accelerated x264 natively.
    On the other hand, a ffmpeg-GUI like iffmpeg https://www.iffmpeg.com, but integrated directly into Compressor with some nice one-click presets for common tasks
    (like rewrapping XDCamHD422 into MXF) would be really awesome!
    Best regards,
    Bernhard
  • Jeremy Garchow
    January 31, 2014 at 5:10 pm
    [Bernhard Grininger] “Yes this is true. But as long as FCP-X consolidates everything to ProRes under the hood, the export at least is fast and causes no loss in quality”
    Yes, true. I just find it’s rather annoying to have to manage all of those non-necessary files and waste the disk space. It would be fine if we could export reference files again.
    [Bernhard Grininger] “I would really appreciate if Apple would integrate OpenCL accelerated x264 natively.”
    Intel’s Quicksync on i7’s actually does a pretty good job, but it is single pass only.
    You can read about it here if you haven’t already: https://www.streamingmedia.com/Articles/Editorial/Featured-Articles/First-Look-Apple-Compressor-4.1-94026.aspx
    MXF4mac, ImEx Suite allows direct export of MXF out of FCPX using Compressor settings. It’s not cheap, but if you need the functionality, it’s well worth it.
    https://hamburgpromedia.com/products/mxf4mac/MXF-Import-Export-Suite/MXF-Import-Export-Suite.php
    Being able to natively import MXF’s is great too. I use it for Sony F55 footage and saves a ton of space (and time).
    Jeremy
  • Bryan Mullennix
    February 1, 2014 at 1:26 am
    Thanks Bernhard for the suggestion of HandBrake, it did the trick! I compared the output between HandBrake and Compressor 4.1 and quality of HandBrake was far superior.
    Thanks again!
  • Bernhard G.
    February 1, 2014 at 9:04 am
    You’re welcome! 🙂
