Activity Forums Adobe Media Encoder Exporting h.264 for web and dvd
  • Exporting h.264 for web and dvd
    Posted by Courtney Varner on August 7, 2015 at 11:15 pm
    I need some simple explanations for the Profile and Level settings in Media Encoder. I’ve tried reading the technical stuff but it all goes over my head. If I had more time to dive deep into it I might be able to understand it, but I don’t.
    Could someone ELI5 me the difference between Profile Baseline/Main/High/ and the Level 3.0/3.1/4.0/4.1/5.0 etc?
    These files get run through Sorenson Squeeze for compression to 360/720/1080/4K and the originals get released on DVD. So what settings should I be using so the most amount of people can view the content without problems, but without sacrificing quality?
    Ryan Holmes replied 11 years ago 2 Members · 1 Reply
  • Ryan Holmes
    August 9, 2015 at 7:36 pm
    Courtney – You’ve stepped into the Compression Vortex! 🙂
    Simplest answer is that a given level (3.0, 3.1, 4.0, 4.1, etc) and profile relate to how high of a data rate and frame size you can encode. I won’t enumerate all of them here, but Wikipedia has it all written down for you: https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
    Ultimately, it depends on your audience that you’re trying to reach and at what resolution/data rate as to how you encode. So if you plan on delivering 4K files at the max data possible to your end user(s) you’ll have to use Level 5.1 or 5.2 in High Profile (300MB/s). But if you’re going for the widest possible audience you’ll have to take into account people who have older devices that may not be able to read that high of a level. For example, people with old Samsung Galaxy phone or an iPhone 4 or 4s. In those cases you need to back your level off to something in the 4’s. For my encoding when delivering to 720p for the web I go back to level 3.1 or 3.2 to ensure the widest possible compatibility range for devices.
    FYI, the current iPhone 6 only reads up to level 4.2 ( https://www.apple.com/iphone-6/specs/ ):
    Video formats supported: H.264 video up to 1080p, 60 frames per second, High Profile level 4.2 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats.
    Hope that makes some sense for you….!
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
