Activity › Forums › Adobe After Effects › Exporting Growing Object
  • Exporting Growing Object
    Posted by Ed Blackford on December 3, 2009 at 4:12 am
    Hello. I created a flourish and exported it via render que as a .mov file. When I try to import it into after effects now it will only import as a project, not footage. When I import the flourishes from videocopilot’s evolution it allows me to import them as footage. Does anyone know what I need to do differently?
    Ed Blackford replied 16 years, 9 months ago 2 Members · 4 Replies
  • Dave Johnson
    December 3, 2009 at 6:53 pm
    In order to answer, it would be heplful to know:
    • what codec the MOV your trying to import is in
    • how exactly you’re importing it (drag & drop, file>import menu, etc.)
    • what version of AE you’re using
    • any other details you can provide
    It’s hard to say without much info, but my guess is it’s one of two things … either there is an issue with the file and AE can only read it as a project file or you have a preference set somewhere that makes your default import type project instead of media.
    Sorry if I misunderstood your question.
  • Ed Blackford
    December 3, 2009 at 8:19 pm
    codec = mpeg-4
    importing by file>import
    AE CS4
    I was following the tutorial on forgingfire.com (if you are familiar with that) on how to make an animated flourish. He forgot to tell us how to export the file correctly. I figured out how to import it as footage after working with it for a while but now it imports with the flourish white and has a black background which i didnt want because now I can’t colorize.
    Maybe the question I should ask is in what format should I export my flourish?
  • Dave Johnson
    December 3, 2009 at 8:59 pm
    Personally, I consider MPEG4 a web delivery format only (not a working/intermediary or mastering format) so I never import MP4s into AE … for details as to why, look at any of Dave LaRonde’s posts that include his “stock AE answer #1”.
    There many good formats and codecs you can use to render out your animation … you just need to choose one with an alpha channel to resolve the black background issue … I usually use Animation, although I’ve also started using PNG a lot lately (PNG lossless video codec, not a PNG sequence).
  • Ed Blackford
    December 3, 2009 at 9:34 pm
    Thanks both Daves. I always use Add to Render Queue but don’t really know much about different video files. Now I am going to start reading up on this so I don’t have to ask about them anymore. Thanks a lot guys
