Activity Forums Adobe After Effects Exporting full video using a Preset
  • Exporting full video using a Preset
    Posted by Remi Belcourt on June 22, 2013 at 1:50 pm
    Hello for the first time, CreativeCow friends:
    I found a preset on youtube, which I am trying to apply on a 3 minute music video:
    youtube.com/watch?v=_0swukAEq58
    It’s a VHS effect, and it is perfection. The only problem, I suppose, is my RAM.
    When I import the full music video into the preset project, the work area becomes just 15 seconds.
    That doesn’t surprise me, as my RAM is 8gb.
    I am fine with working the small portion, so long as I can export the full portion.
    So, can AE CS6 render the entire 3 minutes despite the 15 second work area?
    I would like to know if this is even possible. I will take in any advice I can get.
    Also I am open to look into other alternatives that attain this VHS look.
    Thank you much,
    Remi Belcourt
    Remi Belcourt replied 13 years, 3 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    June 22, 2013 at 5:34 pm
    The Work Area is critical for certain preview options. It is used as the default in/out points stipulated in the Render Queue’s Output Options. You can safely override the default in/out points.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Remi Belcourt
    June 23, 2013 at 1:54 am
    This is excellent! This gives hope once more.
    I will try when I am off work. Although if I have trouble, I may return to this thread. It is great for professional answers (as I am a novice in AE)!
    Thank you much for the answer RoRk.
    Remi Belcourt.
