Activity Forums Apple Final Cut Pro Legacy Exporting frozen timeline into new project
  • Exporting frozen timeline into new project
    Posted by Sherwood Ball on September 7, 2007 at 6:53 pm
    I got no response regarding my earlier HELP post,
    so I did the only thing I could do which was export
    the timeline last chapter of my documentary as a QT.
    I imported the QT into a new project and I can edit parameter
    data fine, I’m just cutting in and out of the QT.
    My Q is:
    I exported the chapter using the DV/NTSC 23.98 option.
    I know this is recompressing the chapter.
    If I re-export the chapter, what setting should I use
    for NO COMPRESSION?
    I can then re cut in the NEW lossless QT for my final export.
    Anyone?
    Thnx,
    Sherwood
    G5 Dual 2.5 GHz
    6G Ram OSX 4.8
    Sata drives
    Final Cut Studio 5.1.1, Logic Audio 7.1
    PS CS2, AE CS2
    Tom Brooks replied 19 years ago 2 Members · 1 Reply
  • Tom Brooks
    September 9, 2007 at 11:17 am
    If you export Quicktime movie (not Quicktime conversion) using your current sequence settings, you will not recompress the footage. When you reimport that, you will have no loss from where you were before. The only difference from your original sequence is that any rendering you have done in the original will be built into the export and any changes you make in the reimported clip that require rendering will add another generation of render to the clip.
