Activity Forums Adobe Premiere Pro Exporting from Premiere (lossless)
  • Exporting from Premiere (lossless)
    Posted by Johannes Schwarz on May 29, 2009 at 1:17 pm
    I’m coming close to finishing my first 70min DVD project. Hurray!
    On my Core 2 Pc with Adobe CS3 I had to split up the project into 10 Sequences to keep Premiere from crashing all the time and have it display the stills correctly (a real pain). I can’t put the sequences all in one final sequence, without it crashing, so I need to export them individually and then re-import the resulting videos into a new Premiere project for some final editing, sound effects etc.
    1.
    How should I export them to get the best quality (lossless if possible)? Most of the used footage is SD off a miniDV Camcorder, but there are Motion graphics and stock footage clips (shot with other camcorders presumably). All my material is progressive, but there is some stockfootage that came interlaced. I tried exporting through Export > Movie , but I seem to get horizontal lines when I play back the file. Is this a DV feature? What do people think of Quicktime, PNG or Motion JPG for exporting quality footage?
    2.
    What recommendations would you make for exporting to a DVD? Would you make the mpeg2 files progressive or interlace them?
    thanks for any suggestions
    Johannes
    Johannes Schwarz replied 17 years, 2 months ago 3 Members · 4 Replies
  • Eddie Lotter
    May 29, 2009 at 1:56 pm
    1. Use DV. I doubt you will see any degradation in two generations of DV encoding.
    2. Defintely interlaced.
    Cheers
    Eddie
  • Johannes Schwarz
    May 30, 2009 at 11:31 am
    Thanks Eddie. I’ll do that.
  • William Jones
    June 6, 2009 at 1:57 am
    Your best option is to export a quicktime with no compression. This will be completely lossless and will keep all of your color information. Those horizontal lines are interlacing and they will always be there unless you export progressive.
    William
  • Johannes Schwarz
    June 6, 2009 at 5:55 am
    Thanks William,
    The exporting is done and 12.000 copies are pressed as we speak (hopefully), but I’ll have a look at the quicktime export next time. My question about the lines was stupid. I was not aware, that the DV export settings were set to interlaced. I had thought that it would keep all those video files as they were (almost all progressive), but then realized my “mistake”,
    Greetings,
    Fr. Johannes
