Activity Forums Apple Final Cut Pro Legacy Exporting from Final Cut to Quicktime issues
  • Exporting from Final Cut to Quicktime issues
    Posted by Kenneth Sutton on August 25, 2011 at 6:00 pm
    I’m trying to export a file to for commercial use and am trying ot fit it for broadcast purposes. I exported a sequence from Final Cut into Quicktime as an mov file then opened it up in QuickTime7 to export as “movie to quick time movie” file. I then tried opening up option and specifying the Apple ProRes 422 HQ as the codec option, but when I play the file after it has exported, it is black. I only hear sound. I’ve exported the file using the “none” compressor and it comes out fine but for whatever reason it will just come out black when I specify 422. Anyone know what might be the issue here and how to resolve it? Thanks.
    Chris Tompkins replied 15 years ago 3 Members · 2 Replies
  • Everest Mokaeff
    August 25, 2011 at 7:28 pm
    Use export as QT Movie w/ current settings if they suit your needs. Otherwise use compressor.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Chris Tompkins
    August 25, 2011 at 9:02 pm
    Ya, you’re taking the long route for sure.
    Finish Edit.
    Change the Codec of your Sequence to Prores.
    Render Full/All.
    Export “Current Settings” self contained.
    Chris Tompkins
    Video Atlanta LLC
