Activity Forums Apple Final Cut Pro Legacy Exporting from Final Cut Pro
  • Exporting from Final Cut Pro
    Posted by Chris Shaw on January 26, 2012 at 3:55 pm
    Hi I’m current using After Effects and Final Cut Pro 7 to create a video that will be burnt to a disc and handed to a guy at an event tomorrow who’ll copy it to his Macbook Pro. He’ll then run the video off there.
    I’ve been using the ProRes 4444 codec when exporting from After Effects to Final Cut. The quality is mindblowingly good. Is is possible to just use this codec for the final output through compressor? Does it work on any Mac?
    If not what is a good workflow to stop banding and make things crisp and super sharp? The final output will be in 720p.
    Any advice is really appreciated.
    Chris
    ps I accidentally posted this in the After Effects section too
    Shane Ross replied 14 years, 7 months ago 4 Members · 6 Replies
  • Chris Tompkins
    January 26, 2012 at 4:22 pm
    I would not hand over a ProRes codec file to someone to play off a computer. They need to have that codec on that comp. to play it.
    Start with the Youtube/Vimeo HD preset and go from there:
    1280×720
    deinterlace (if interlaced only)
    5,000kbs
    .h264
    .mov
    Chris Tompkins
    Video Atlanta LLC
  • Chris Shaw
    January 26, 2012 at 4:46 pm
    Thanks for your reply Chris.
    I emailed the company and they assured me it would play fine on their Mac, but saying that doesn’t that codec only come with Final Cut Pro?
    The reason I ask is because I’m getting a serious issue with banding when I set it to the above. I’ve put the ‘reduce banding’ video filter on in Final Cut Pro but it looks nasty once rendered out from Compressor.
    Chris
  • Shane Ross
    January 26, 2012 at 5:33 pm
    The ProRes encoder for PR 4444 comes with FCP 7. But any computer with QT7.6 can watch it…the ProRes decoder is in the latest QT update. Delivering ProRes 4444 is a great option…as good of quality as Animation codec, but 1/3 the file size.
    Shane
    Little Frog Post
  • Chris Shaw
    January 26, 2012 at 5:36 pm
    Thanks Shane, so it’s not amateur for me to use it as a final output for my videos, when we use the same company at our events?
  • Rafael Amador
    January 26, 2012 at 5:46 pm
    Prores444 is perfect to export from AE, but once you bring it to FC, export Prores or Prores HQ.
    No point on mastering in Prores444. Most of all when you are going to an MPEG-2/420.
    rafael
    http://www.nagavideo.com
  • Shane Ross
    January 26, 2012 at 6:25 pm
    [Chris Shaw] ” so it’s not amateur for me to use it as a final output for my videos”
    Lord no. It’s a great codec.
    Shane
    Little Frog Post
