Activity › Forums › Adobe After Effects › exporting from FCP to AE
  • exporting from FCP to AE
    Posted by Scott Di lalla on July 24, 2007 at 5:28 pm
    First off this is my first post, but I have lurked for a long time and learned a bunch. For those who have started Creative Cow and the ones that keep it going, thank you.
    I’m a new user of AE 7 but because of my background in photoshop and illustrator I seem to have a good grip on the basics.
    I’m using FCP to cut my documentary and AE 7 for color correction, flash cuts.. etc.
    First, the way I export from FCP. I take a captured clip (from a bin not in my timeline) then I go to – file- export
    Todd Gillespie replied 19 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Duff
    July 25, 2007 at 6:22 am
    i feel automatic duck is a must have for what you are doing … it sends across your entire timeline, with transitions and some effects … and it links back to the original media, so you are not duplicating your media… then you can do all your grading .. then render out using the render queue.
    without automatic duck … i think you pretty much doing it the correct way .. except I wouldn’t use the desktop to manage your media … create some folders that are easy to understand … the problem with exporting the entire doco as one clip means that you wont have control over individual shots … hmmmm, maybe someone else can suggest a good way to do it without the duck…
  • Scott Di lalla
    July 25, 2007 at 4:54 pm
    Thanks for the feedback. It seems that I am importing and exporting the media correctly so I’m happy there. I will do some more research to see if I can find any tricks and tips about timeline issues.
    As far as the saving to my desktop I am in total agreement. I just used that as an example for my question regarding exporting/rendering out of AE and into FCP.
    Thanks again.
    Scott
  • Todd Gillespie
    July 25, 2007 at 7:23 pm
    Duff and Dave are spot on.
    If you are wanting to create transitions with clips from FCP -in AE, then you will diffinately need Automatic Duck. You can manage to export/import when you are going clip by clip, but for transitions and color correction-you’ll need Duck.
    To save on time and space, I usually would export a ‘by-reference’ (not self-contained) file out of FCP, then when you go back to FCP out of AE I would create an animation file, then downconvert in FCP. But the by ref file will only work if you are using the same machine for AE.
    Todd at UCSB
    Television Production
  • Scott Di lalla
    July 26, 2007 at 8:38 pm
    “I usually would export a ‘by-reference’ (not self-contained) file out of FCP, then when you go back to FCP out of AE I would create an animation file, then downconvert in FCP.”
    Todd would you be able to explain this part step by step? I’m using FCP and AE on the same machine. thanks
    Scott Di Lalla
    https://www.choppertown.net
    https://www.brittown.net
  • Todd Gillespie
    July 27, 2007 at 5:14 pm
    Hi Scott,
    I’m not sure which part of the process you want explained…so I guess I’ll try to cover it all.
    When exporting out of FCP, you DON’T need to create a self-contained file. Since you are going to use it in AE then render a new file out of AE, the FCP export file is really an intermediate file that will never be used on it’s own. Hence the quickest, smallest, and easiest file is best. When exporting out a ‘by reference’ (not self contained) file will be very small, it will export out faster, and the file will function the same as a normal self-contained file. By reference files can get you into trouble because they will always need the original files (digitized media) to play properly.
    Out of AE I will usually render to the Animation Codec. One, I tend to have alpha channels, but more importantly the video/animation will look better when rendered out to Animation, then converted to DV in FCP. Plus, for us at least, we may only need a video in DV quality now, but maybe in a couple of months or next year, we might want the same video in a better codec. By keeping the ‘master’ video/animation in a higher quality, you are giving yourself better options down the road.
    I hope I was clear enough.
    Cheers,
    Todd at UCSB
  • Scott Di lalla
    July 31, 2007 at 4:04 pm
    Thanks Todd for taking the time to explain it. Once last question. To export out of FCP as a ‘by reference’ file do I just unclick “make movie self contained?”
    Thanks again,
    Scott
    Scott Di Lalla
  • Todd Gillespie
    August 1, 2007 at 10:26 pm
    Sorry,
    I didn’t see the repost.
    Yes, just uncheck self contained.
    Good Luck,
    Todd
    Todd at UCSB
