Activity › Forums › Apple Final Cut Pro Legacy › Exporting from FCP: Out of Memory?
Posted by Tom Laughlin on January 26, 2012 at 9:31 pmI’m exporting a video from off the timeline, as a QT .mov file, and it doesn’t matter if it is to an external hard-drive, or internal drive, or to a network drive, or to the desktop, it will not export, it says “Out of Memory”. Render Manager? Well, I’ve got plenty of memory, and deleting Render files doesn’t help, there’s more than enough room for this 2-3 GB file anywhere.
Anyone have any ideas?
Tom Laughlin
Producer/Editor
Digital Chop House
Salt Lake City, UtahMichael Gissing replied 14 years, 7 months ago 3 Members · 9 Replies -
Shane Ross
January 26, 2012 at 9:47 pmRender before you export. get the error then?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Tom Laughlin
January 26, 2012 at 10:16 pmCan high-res stills cause this error? If there are quite a few still images? 4500×2500 sized stuff? Everything is rendering fine…
Tom Laughlin
Producer/Editor
Digital Chop House
Salt Lake City, Utah -
Shane Ross
January 26, 2012 at 10:18 pmYes, high res stills over 4000 pixels can cause this, that’s why I asked. FCP has a 4K media size limit. This means video and stills. All stills need to be under 4000 pixels.
Shane
Little Frog Post
Tom Laughlin
January 26, 2012 at 10:40 pmBut isn’t there a way to take the images into Photshop, and lower their quality or change their color space or something, so that it still maintains the resolution, but the files are not so huge? In other words, to avoid re-scaling and adding motion to the images, more of an asset refresh?
Tom Laughlin
Producer/Editor
Digital Chop House
Shane Ross
January 26, 2012 at 11:06 pmEven if you lower the DPI to 10, that won’t affect anything…as DPI is meaningless in Video. All that matters is the pixel dimensions. Those are what need to change, and when you do that, yes, the pictures will get smaller, and you will need to redo the moves.
Yes, it stinks.
Shane
Little Frog Post
Tom Laughlin
January 26, 2012 at 11:24 pmSo, I’m in Photoshop, if I change the DPI from 300 to 72, this looks to be a good workaround. I’m unchecking “Resample Image”. It’s changing the dpi, but not the resolution, so looks like this should work ok.
Tom Laughlin
Producer/Editor
Digital Chop House
Shane Ross
January 26, 2012 at 11:26 pmAgain…DPI is meaningless in video. And it isn’t the file size that is choking FCP, it is the pixel dimensions.
But, try this and see.
Shane
Little Frog Post
Tom Laughlin
January 26, 2012 at 11:33 pmI’ve not yet relinked the old assets with the new assets, stills, when I do and re-link, and re-export, I’ll let you know. The file sizes went from 7MB to 1-1.5MB…
Tom Laughlin
Producer/Editor
Digital Chop House
Michael Gissing
January 26, 2012 at 11:45 pmI usually just halve the image size and then it is easy maths to rescale image size and any moves.
An alternate approach is to do the scaling & moves first in Motion and then export a quicktime to drop into FCP.
