Activity › Forums › Apple Final Cut Pro Legacy › Exporting from FCP Into AvidXpress
  • Exporting from FCP Into AvidXpress
    Posted by Jimmy Stewart on January 18, 2007 at 6:04 pm
    Hello,
    I am exporting a Quicktime from Final Cut Pro into Avid Xpress Pro. I shot with the Vericam HD. What is the best export setting? So far Im thinking its Sorenson, 1280x720HD. Would I Deinterlace or not?
    Jimmy
    Jimmy Stewart replied 19 years, 8 months ago 2 Members · 2 Replies
  • Matt Larson
    January 18, 2007 at 8:43 pm
    Don’t use Sorenson! That’s a delivery codec, which is too compressed if you are going to Avid. The best option would be Animation codec at best setting 1280 x 720. You won’t need to deinterlace since you shot it in progressive. Keep in mind this will be a huge file if the clip is very long. Google the Sheer Video codec, it’s great for what you need. If the Avid is on a Mac, you might be able to use the DVCProHD codec and import that into Avid.
    Also, if Avid can capture DVCProHD, why not try sending it out firewire from the FCP timeline to a DVCProHD tape and then capture in Avid?
  • Jimmy Stewart
    January 18, 2007 at 9:05 pm
    What is a delivery codec? Is that for a final product to show people? Thanks for that.
    I don’t have a deck so I cant export out and then redig, but I do have a Mac, so I can try the DVCproHD codec. Is that what it is called? The clip is about 3 minutes long. Ill google that other codec you mentioned.
    Thanks again!
