Activity › Forums › Panasonic Cameras › Exporting from FCP – 7 boxes
Posted by Joe Schaak on March 20, 2009 at 4:14 pmWhen I export from FCP 6.0.5 using QT Conversion, the QT shows up with 3 boxes on the left edge, 3 boxes on the right edge, and 1 box in the middle. I can work around it if I switch the sequence settings from DVCPro to Apple ProRes 422, but I’m wondering what the underlying issue is? Is it an issue between the P2 Driver and FCP?
Greg Booth replied 17 years, 5 months ago 3 Members · 7 Replies -
Noah Kadner
March 21, 2009 at 6:06 pmReally? Can you post a screenshot of that- sounds odd. Shift Apple 3 for a screenshot, then photobucket to host it.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
https://www.callboxlive.com -
Noah Kadner
March 22, 2009 at 12:35 amWow- that’s truly weird. If I had to guess I’d say there was a problem with the original recording that caused those glitches. It might not show up in FCP though. I’d try re-importing a clip and see if it helps.
Noah
Greg Booth
March 22, 2009 at 3:20 pmHi Joe,
It looks like you installed our demo Calibrated{Q} DVCProHD Decode code (that’s the watermark pattern) – which isnt meant to be installed on computers with FCP. The uninstall instructions are in the ReadMe in the /Applications/Calibrated/Doc folder.
Cheers,
GregCalibrated Software
Noah Kadner
March 23, 2009 at 6:55 amWow- may I suggest some very subtle text to identify the watermark in the next version? I would never have known where it came from. 🙂
-Noah
Joe Schaak
March 25, 2009 at 7:57 amI don’t remember installing your software at all. I don’t find a “Calibrated” folder anywhere in my Applications folder.
Have I missed something?
Greg Booth
March 25, 2009 at 12:18 pmHi Joe,
Open up your ‘Macintosh HD’ in Finder and look in your /Library/QuickTime folder – is there a CalibratedDVHDCodec.component? If so, delete it and restart.
Greg
