Activity Forums Apple Final Cut Pro Legacy Exporting from FCP 6 with an alpha channel
  • Exporting from FCP 6 with an alpha channel
    Posted by Justin Coleman on August 6, 2007 at 6:50 pm
    Hi Guys,
    This is a stupid one considering that Ive been using FCP since v2…I cant work out how to export a QT whilst preserving the alpha channel.
    Im using DVCPro HD at 25p. Using the Blue and Green Screen filter to key footage and export so my client can import into AE and see the alpha. The workflow is set in stone and I just cant work out how to do it. Ive tried exporting using QT conversion into a Animation codec with millions of colour + and it doesnt preserve the alpha.
    Any ideas?
    Justin
    Jeremy Garchow replied 19 years, 1 month ago 3 Members · 2 Replies
  • David Roth weiss
    August 6, 2007 at 7:49 pm
    What you’re doing should work, but why don’t you export as 32-bit sequential TGA or PICT files?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Jeremy Garchow
    August 6, 2007 at 8:07 pm
    The timeline has to be unrendered, then export as Animation+alpha. Duplicate the sequence, open it, select all (Apple-a), hit control-b, then hit control-b again. That will shake loose the render files. Then export as animation, millions+
    Jeremy
