Activity › Forums › Apple Final Cut Pro Legacy › Exporting from DVCPro HD720P60 to 4:3
  • Exporting from DVCPro HD720P60 to 4:3
    Posted by John Scherf on June 20, 2008 at 10:25 pm
    I’m having trouble exporting an uncompressed Quicktime of a DVCPro HD720P60 sequence. I’m telling it to crop the image to NTSC 720×480 4:3 but it won’t. I keep getting very thin people doing very thin things. I feel fat enough already and frankly Compressor terrifies me because of my inexperience with it.
    HELP! and Thanks – this forum is cool
    John Scherf replied 18 years, 3 months ago 2 Members · 4 Replies
  • Michael Sacci
    June 20, 2008 at 11:04 pm
    Start with the preset in Apple>Format>Quicktime>Uncompressed 10-Bit (or 8-Bit)
    Click on Geometry Tab
    Source Inset Cropping
    Crop to 4:3 1.33:1
    Dimensions (encoded pixels)
    Frame size: 720×480
    Default for size
    Output Image Insert (Padding)
    Padding 4×3 1.33:1
    Click Save As and you should be good to go. Of course it is cropping the right and left of the image.
  • John Scherf
    June 20, 2008 at 11:13 pm
    Michael – is this using Compressor?
  • Michael Sacci
    June 20, 2008 at 11:17 pm
    Sorry yes, don’t let compressor scare you, all it can do is make a bad file and you can just delete it if you don’t like it, it cannot hurt you, I promise.
  • John Scherf
    June 20, 2008 at 11:25 pm
    Yes, I found everything as you said – will woodshed with the Compressor manual and give it a go
    Thanks !!
    js
