Activity Forums Adobe Premiere Pro Exporting from AE to Premiere for Tape Printing
  • Exporting from AE to Premiere for Tape Printing
    Posted by Kim Huston on January 30, 2009 at 2:36 am
    I cannot get a file that doesn’t need to be rendered when put back into Premiere Pro for tape export.
    I’m using the Apple Animation codec, making sure it’s dropframe and 29.97fps. And that’s exactly what the project in Premiere is set as.
    My After Effects Settings:
    NTSC DV
    Width: 720
    Height: 480
    [ ] Lock aspect ration 3:2 (not checked)
    Pixel Aspect Ratio: D1/DV NTSC (0.9)
    Frame Rate: 29.97
    Resolution: FULL (720 x 480, 1.3 MB per 8bpc frame)
    And the duration and start timecode are all written in drop (;)
    In the Advanced tab:
    Rendering plug-in: Advanced 3D
    [ ] Preserve frame rate when nested or in render queue
    [ ] Preserve resolution when nested.
    I don’t have any nested comps
    My output settings in the render queue are:
    Render Settings:
    quality: Best
    resolution: Full
    size: 720 x 480
    disk cache: Read Only
    [ ] Use Open GL Renderer
    proxy use: use no proxies
    effects: current settings
    solo switches: current settings
    guide layers: all off
    color depth: current settings
    Frame blending: on for checked layers
    field renderer: off
    3:2 pulldown: off
    Motion blur: on for checked layers
    time span: work area only
    frame rate: use comp’s frame rate (29.97)
    Options:
    [x] use storage overflow
    [ ] skip existing files (allows multi-machine rendering)
    Output Module Settings:
    Format: Quicktime Movie
    Embed: Project Link
    Post-Render Action: None
    [x] Video Output
    Channels: RGB (Format options Animation, Spacial Quality = High (100) FPS 29.97)
    Depth: Millions of Colors
    Color: Premultiplied (Matted)
    No stretch, no crop, no audio.
    My Premiere Project Settings:
    Editing Mode: DV NTSC
    Timebase: 29.97 frames/second
    Frame size: 720 horizontal 480 vertical 4:3
    Fields: Lower Field First
    Display format: 30 fps Drop-Frame Timecode
    Sample Rate: 48000 Hz
    Display Format: Audio Samples
    Under the Video Rendering tab in Project Settings:
    [ ] Maximum Bit Depth (not checked)
    Previews:
    File Format: DV NTSC
    Compressor: DV NTSC
    Color Depth: Millions of colors
    [x] Optimized Stills (is checked)
    The only thing that seems to be different is the fields. I don’t think it’s specified in the AE project.
    Are the two programs not using the SAME Apple Animation codec somehow?
    Kim Huston replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
