Activity Forums Apple Final Cut Pro Legacy Exporting From a Compressor in Final Cut
  • Exporting From a Compressor in Final Cut
    Posted by Abhishek Sharma on April 26, 2009 at 5:38 am
    Hi Dis is Abby,I just want to know how to export a sequence in Final Cut using a compressor,As there are several options in the compressor.I want to export the file in The best DVD Quality its a 120 minutes sequence.
    Abhishek
    Zane Barker replied 17 years, 5 months ago 2 Members · 1 Reply
  • Zane Barker
    April 26, 2009 at 6:01 am
    First off there is no need to post the same question twice. (you asked the same question just a few threads down)
    [Abhishek Sharma] “I want to export the file in The best DVD Quality its a 120 minutes sequence”
    Well your answer is quite simple then use the “DVD: Best Quality 120 minutes” preset in compressor.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
