Activity Forums Adobe Premiere Pro Exporting Frame From Premiere Pro CS5 and Adjusting In Photoshop Importing Back Into Premiere
  • Exporting Frame From Premiere Pro CS5 and Adjusting In Photoshop Importing Back Into Premiere
    Posted by Alvin Lowery on February 4, 2013 at 5:53 pm
    When I export a frame from the Premiere timeline to work on in Photoshop and import back into Premiere Pro the aspect ratio of the still frame is wrong. I click on the clip and scale to project size but still get the wrong aspect ratio. Any help appreciated.
    Ivan Myles replied 13 years, 7 months ago 2 Members · 3 Replies
  • Ivan Myles
    February 4, 2013 at 8:34 pm
    What is the aspect ratio for the file as shown under “Interpret Footage”? What is the aspect ratio of the sequence?
  • Alvin Lowery
    February 4, 2013 at 10:24 pm
    The sequence setting is HDV 1440 X 1080. I right click the clip but do not see interpet footage.
  • Ivan Myles
    February 5, 2013 at 7:31 am
    Right-click the source file in the project panel. Depending on which release of Premiere you are using, look for either “Interpret Footage” or “Modify” as an option in the right-click pop-up menu.
