Activity Forums DaVinci Resolve Exporting for sound/grade handover with Resolve free version
  • Exporting for sound/grade handover with Resolve free version
    Posted by Ann Foo on March 27, 2025 at 4:22 pm
    Easy one: Can the free version of Resolve export handover assets to sound (protools) and grade? Or must I buy the paid version to do this?
    Dedric Terry replied 1 year, 2 months ago 4 Members · 4 Replies
  • Devrim Akteke
    March 28, 2025 at 7:39 am
    It should probably be ok. The free version basically limits the resolutions above 4k and 8 bit and some effects don’t work.
    You can check the below list.
    The free version allows you to export videos in 4K resolution — which is more than enough for most content creators. However, there are some limitations.
    • No access to certain advanced features like multi-GPU support, which speeds up rendering, and advanced noise reduction aren’t available in the free version.
    • Some of the powerful AI tools available in the Studio version, such as the Magic Mask and Face Refinement, aren’t included in the free version.
    • There are several effects you won’t be able to use, such as Grain and Lens Distortion.
    • While the free version contains scopes for your grading, the professional HDR scopes are missing from Davinci Resolve free.
    • The free version is also missing the tools to grade 3D projects or synchronize Davinci systems for remote grading.
    • The free version supports only 8-bit formats, while the Studio version supports 10-bit formats.
  • Ann Foo
    March 28, 2025 at 2:04 pm
    I’m an Offline features editor, usually working with 1080p proxies. So from what you’re saying, sounds like the free version could handle a feature length 1080p export to sound (AAF) and grade (XML/EDL) handover. Thanks!
  • Michael Gissing
    March 31, 2025 at 3:36 am
    If the free version has the protools export preset on the delivery page then it should be fine. If you are sending the project to the grade and they are using Resolve, then you send a Resolve timeline, not an xml. No point in going through a different translation unless the grade facility is using an older version of Resolve
  • Ann Foo
    June 15, 2025 at 9:44 pm
    I ran a test with a sound designer friend and sending to protools worked fine. Never want to assume they are grading in resolve so I always want to know if an XML will work, but that’s something I might test later down the track.
  • Dedric Terry
    July 2, 2025 at 11:43 pm
    Probably a late answer, but for others reading in, yes, for audio post (my arena), the free version will export AAFs. I have done this many times. I mix in Fairlight, ProTools, and Nuendo, and have imported AAFs from clients/Resolve editors in all three.
